Turbo w/ stock internals
Old Jan 16, 2008 | 08:12 AM
civicrippa98's Avatar
Default Turbo w/ stock internals
im looking at boosting my 98 HX in the near future and eventually beefing the internals. I already got a skunk 2 adjustable cam with adj. gears that should have the proper lobe and duartion for this turbo setup. The turbo is a complete kit from Procivic.com it is a T-25 turbo with intercooler and all essentials. Should the stock pistons, rods and crank be able to handle 7-10 psi, about 180 horse - 200 horse? Do u think the motor will still be a little reliable if i run the street at 5 psi and save the 10 psi for the weekends?
Old Jan 16, 2008 | 08:14 AM
Default RE: Turbo w/ stock internals
oh ya forgot to mention, D16Y5 5 speed. Turbo should still work with 2.5" catback, full cold air, and MSD ignition
Old Jan 16, 2008 | 09:24 AM
bcrichguitars's Avatar
Don't go over 9psi with stock internals. I do about 9psi and my head has lifted a little, so make sure you get ARP bolts.
Old Jan 16, 2008 | 09:40 AM
FlipHKD720's Avatar
^ headstuds at the least, but its more about the power, not PSI. 200 hp is prolly safe, just get a good tune and you should be good for a while until you re-do the engine internally
Old Jan 16, 2008 | 01:09 PM
MY99SI's Avatar
ORIGINAL: civicrippa98
where can i get myself an adjustable cam?
Old Jan 16, 2008 | 07:53 PM
Sweet deal, thanks for all of your help, when you say get a good tune, do you mean like the right size injectors and the right air/fuel ratio? So should i buy an E-Manage or something like that? In response to the guy with the 99 SI, you can get adjustable cams on www.procivic.com www.autopartswarehouse.com and there is a few others.
Old Jan 16, 2008 | 07:57 PM
SovXietday's Avatar
1) It's adjustable cam GEARS.
2) Why the heck are you boosting an D16Y5? If you're going to boost an SOHC at least boost the performance based ones. D16Z6/D16Y8, they're cheap and easy to swap.
3) Read the stickies.
Old Jan 16, 2008 | 08:32 PM
FlipHKD720's Avatar
yes, tuning meaning chipping a Honda OBD1 ECU, brining the car to a dyno/street tuner (preferably dyno) and having them fine tune the ECU to exactly how it needs to be. It deals with a/f ratio, timing, and prolly a few other things. You will need to upgrade your fuel system, usually injectors, maybe a fuel pump, sometimes a pressure regulator and fuel rail.
2000siman
Jan 19, 2010 04:17 PM
dave_57204
Mar 14, 2008 11:00 AM
tombakers
Feb 13, 2007 10:49 AM
redridinhood
Sep 11, 2006 10:19 PM
ballplaya4eva07
14
Mar 7, 2005 09:06 AM
