What engine to boost?
Old Apr 25, 2007 | 08:16 AM
  #51
Default RE: What engine to boost?
lol, some sort of grocery list.. You just pm'ed me about it the other day
https://www.hondacivicforum.com/m_400322/tm.htm
Old Apr 25, 2007 | 11:21 AM
  #52
the_turtle's Avatar
ORIGINAL: Sldwys11687
Alright, i get it alread...but im just figuring that its easier to build a B because there are more parts readily available for the B series...but just for kicks and giggles, any brands or sites u guys can give me to look up D series parts? Cuz if i can cheaply build up my D then i'll go for it...and how but a mustang gt killer for a goal? Better?
well...find me ANY good clean low miles B series block for $70...and for links... laskyracing.com
that was really dumb...d series parts are SOOO much cheaper to find than b series parts.maybey super awsome aftermarket racing parts are a tad harder to find (but hey, the d market is really growing) but stock parts are a peice of cake to find...and like i said...services for D's (p/p, piston kits/ valve train kits) are really increasing.
Old Apr 25, 2007 | 12:43 PM
  #53
Sldwys11687's Avatar
Cool, another quick question. Would any D16Y8 parts fit on a D16Y7 engine? Like aftermarket camshafts and pistons and the like?
Old Apr 25, 2007 | 12:45 PM
  #54
StifflersMom's Avatar
Cat Fuсker
camshafts from a Y8 will not interchange with Y7, the blocks are identical, so pistons are the same and rods are the same and all else is the same...
Old Apr 25, 2007 | 12:53 PM
  #55
So then i guess it would be easier to modify if i got an EX Y8 head and converted to VTEC?
Old Apr 25, 2007 | 01:16 PM
  #56
Cat Fuсker
Yeasier - yes. I personally don't like the idea of mini-me if you're goign to boost, but that's just me and my personal preferences. I like to keep it simple:-D
Old Apr 25, 2007 | 01:20 PM
  #57
FlipHKD720's Avatar
its called a mini-me swa and you can find loads of info about it. Google or HCF search.
I'm with Roto though, yea VTEC is nice, but if you're gonna boost the mini-me is another $500 you could be spending on your turbo kit.
Old Apr 25, 2007 | 02:44 PM
  #58
Remmy's Avatar
ORIGINAL: Forty04
Dude, a 300hp RWD car is a completely different monster from any high powered fwd. If you were reallya "veteran in this game" you'd know about a little thing called torque steer. Not to mention, good luck hooking up off the line on street tires...
neither the GSR nor the b16 are considered "top of the line" for boost apps. As I mentioned on the first page, build an LS/VTEC
I fully agree. I had to drop the compression to run boost properly in my B16. I am pushing 15psi in that thing and let me tell ya, the first time I drove that car and slammed the gas not knowing what torque steer was, I almost drove straight into a wall. My car is at the point to where you mash that gas that it ends up fighting you to swerve. I will state that any 300+whp civic without crazy extensive suspension work is just plain pointless and stupid unless you like to go to tire burning competitions.
Old Apr 25, 2007 | 02:56 PM
  #59
Remmy's Avatar
Oh and for the record, to achieve that much power, you WILL HAVE to tear apart your block. I wanted a dependable resonably highpower civic. I have a motor that can withstand 350whp daily. But its my DD so its floating around 250 right now.
So in order to do that, I had to rebuild that block. $7000 later, I have my dependable DD
Not to mention the LSD tranny, and the axles, and the $3k Greddy kit and the $1,500 Apexi Power FC stand alone setup, and the boost controller, and the turbo timer, and the a/c relocation kit.
Need I go further? Because I could if you need me to.
Old Apr 25, 2007 | 03:03 PM
  #60
Kedawei's Avatar
ORIGINAL: Roto
Pistons are different.
Regardless I would skip the Y series and play it safe with a Z6, A6, or D15 variant. Too many spun rod bearings. Just not worth the risk for me.
