What engine to boost?
Old Apr 29, 2007 | 09:09 PM
  #81
Kedawei's Avatar
Default RE: What engine to boost?
ORIGINAL: Sldwys11687
when u use that zeal autowerks site, it's bad if you got negative number right?
If you get a negative as your compression result, then yeah you've put the pistons through the cylinder head.
Old Apr 29, 2007 | 11:29 PM
  #82
Sldwys11687's Avatar
Yeah, i got a -.007 in the piston to deck height
Old Apr 30, 2007 | 12:04 AM
  #83
Kedawei's Avatar
Ah that is different. All that means are the pistons are sitting -.007 out of the block. I've heard of people going .02 out the block, so .007 shouldn't be a problem. You would definitely want to clay it though, to make sure the valves won't hit the tops of the pistons. I can't remember what piston-to-valve clearance needs to be. I wanna say .040"?
Old Apr 30, 2007 | 12:18 AM
  #84
Ok, cuz i was doing the calculatoins and i did a complete B16A engine, only thing i changed was the pistons to B16B. I got a CR of 11.91:1 a Rod/Stroke ratio of 1.73 but then i got the piston-to-deck height of -.007.
Old May 2, 2007 | 06:47 AM
  #85
Quick question on rod to stroke length. Would it be better to go with a stroke length of 1.73:1 like in the b16 or 1.58 like the b18, cuz i read that the higher the stroke is to 2 the better for high reving engines, like formula cars meaning that it stays in the power band longer while the b18's lower stroke helps on torque.
Fejery4491
Aug 6, 2006 04:26 PM
usmc2b2004
Feb 27, 2006 12:06 AM
str8racn
Nov 10, 2005 11:53 AM
nachoman
May 23, 2005 02:37 PM
smokingemcee
May 17, 2005 03:18 PM
