What internals do i need to upgrade when running high psi?
Old Dec 9, 2009 | 10:00 AM
1.7lciviclx2001's Avatar
Default What internals do i need to upgrade when running high psi?
Hey i just bought all this stuff, and i want to run i hefty turbo.. what internal parts do i need to upgrade to run over 12psi?
this is what i have
B20Z2 VTEC longblock
Eagle rods
JE 11.5:1 pistons
King Motorsports Stage 2 Ported B16 cylinder head
Supertech OS valves (+0.5mm intake/+1.0mm exhaust)
Supertech dual valvesprings and retainers
CTR camshafts
Crower adjustable cam gears
Hondata Intake Manifold gasket
King Motorsports extended exhaust/intake manifold studs
Skunk2 Pro Series Intake Manifold
RC 310cc injectors
ARP Headstuds
ARP Flywheel bolts
ACT Stage II clutch/pressure plate
Brand new OEM headgasket
Resurfaced OEM flywheel
Skunk2 Header
Omnipower testpipe
Skunk2 catback Exhaust
B16 transmission with ITR LSD and 4.785 Final Drive
New axles
Old Dec 9, 2009 | 02:14 PM
Do you have ARP rod bolts? I would go with bigger injectors (at least 550s) I really can't see anything else that would pose as a problem to be honest.
Old Dec 10, 2009 | 07:25 AM
It's not an internal part, but don't forget the MAP sensor
2000siman
Jan 19, 2010 04:17 PM
bcrichguitars
17
Jul 18, 2008 09:31 AM
00IntegraLS
Jul 2, 2008 03:26 AM
Stumasters
Mar 19, 2007 01:59 PM
ProjectGSR
Oct 19, 2006 08:12 PM
