Would you do this?
Old Oct 25, 2006 | 11:59 AM
Rocko790165's Avatar
Default Would you do this?
Ok if a friend of yours had a D16y7 with around 106XXX miles on the motor which included the tranny, ECU, and axles for around 250 or so, and you could get a TD05H turbo with manifold for around 100 what would you do. How would you build the motor for boost any info or ideas would help thanx.
Old Oct 25, 2006 | 12:08 PM
WhtRice's Avatar
Member
Default RE: Would you do this?
ORIGINAL: Rocko790165
I'm building my D16Y7 right now for boost, first look into a mini me swap, you'll get vtec and some better power right off the bat, go with a z6 cylinder head and intake or Y8, i'v ebeen told its easier to tune the Z6 and over all it'll perform smoother, also you'll find more parts for the z6 cam wise. But before anything do a leakdown test/a compression test to make sure all the rings hold and the motor isnt going to just flop under boost. you wont need the ECU because you'll be swapping it in the mini me conversion, then i recommend new gaskets which you'll be doing anyways and ARP head studs to keep the head from rising off the block under boost.
thats all i can think of but im sure more people will chirp in, sounds like a sweet deal but see if you can do a compression test before paying him the money.
Old Oct 25, 2006 | 12:12 PM
I know its in really good condition and he did a compression test right before he took it out plus my motor has a bad piston ring.Thank you for the help.
Old Oct 25, 2006 | 01:00 PM
WhtRice's Avatar
Member
no prob bro
akskimaster
Mar 1, 2009 11:13 AM
inthezoneac
Nov 10, 2008 03:08 PM
ef4life
Jul 26, 2007 09:11 AM
sandrider123
May 8, 2007 11:38 PM
jimbolion
Apr 4, 2007 09:38 PM
