18's on del sol
Old Aug 10, 2005 | 05:15 PM
batmangothamcity's Avatar
Default 18's on del sol
iv got a 95 del sol sohc esi, its dropped on gmax dampers and springs by 40mm. i was wondering if il get 18's on with a 35tyre and not have any probs with scrubbing? i know this is a civic forum but cudnt find a del sol forum so thought you guys could help me out, ny help would be great, iv bin told that the del sol has the same chasis as the civics?!?!
Old Aug 10, 2005 | 11:35 PM
bleedhondos's Avatar
Default RE: 18's on del sol
Its going rub, maybe you should stick to 17's
Old Aug 11, 2005 | 10:01 PM
slvcivic00's Avatar
18's are going to be a little big on the car, but you can do it. 215/35/18 or 215/30/18 would be the closest to stock sizing, don't go any wider than 215 or you will start to rub the tires. I would personaly go with 17's 205/45/17 will put you almost right on with stock size and you won't have any problems with rubbing.
Old Aug 11, 2005 | 10:14 PM
Pete's Avatar
its going to be a BuUmMpPYyYyY *** rIdE!!!
Old Aug 12, 2005 | 06:05 AM
cheers for that, i had a fiesta mk3 with 17's on a 60mm drop and had a bit if scrubbage bt got the arches done to sort it. jus dont want all that hassle again when it comes to mot time
livejamie
Aug 12, 2011 06:53 AM
Faramire
Aug 1, 2010 11:42 AM
Lab Rat 21
Aug 23, 2004 10:37 PM
bingis
May 22, 2004 12:56 AM
sol2k
May 4, 2004 09:41 PM
