Air Suspension
Old Mar 27, 2007 | 10:11 PM
ltkenbo's Avatar
Default Air Suspension
How much would a decent air suspension system? (minus the compressor).
Old Mar 28, 2007 | 09:20 AM
absoulute's Avatar
Default RE: Air Suspension
i don't run decent air ride but a good air ride cost about 2000 with out compressor.......decent or low par air ride will just have u kicking yourself in the long run and u will be fixing the air all the time. make sure u get copper elbows between valves and compression fittings.
Old Jan 7, 2008 | 06:50 PM
twstd02's Avatar
ART (Air Ride Technologies) makes a good replacement struct, but they are $$$ but well worth it.
Old Jan 7, 2008 | 07:03 PM
jhsplaya08's Avatar
i agree, air ride technologies....
Old Jan 10, 2008 | 02:43 PM
well puting together a setup you want to plan it all at first... cause if you want FASTER switches then you have to upgrade the whole plumbing....
what im doing is going 1/2inch lines/ valves right off the back! if its TO FAST for me... thiers always reducer/filters/slow downs i can use to fill and dump...
im puting a kit together thats from some used parts... used air cans and some used air valves will get my started BUT i will be buying new valves for all the mains....
using the used extras ones to dog leg or backups.....
all new lines and such. but for a decent start up system.... depending on what all ya get... size valves, air lines, air tank/tanks, compressor/compressors, gauges, and any extra toys you want to get...
ive got 6used 1/2valves, 4 used air cans with civic brackets, and 50ft of 1/2inch lines new, and so far i have 350bucks spent on those parts,
i figure with the gauges i want and new valves i estimate 700bucks more and ill have everything i need to bolt it up to my 94civic
TeamExodusPres
13
Aug 10, 2007 05:11 AM
Chopsta
Apr 22, 2007 07:48 AM
ryantann
Jan 1, 2007 10:27 AM
Jordon 92
Feb 18, 2006 06:32 PM
grncivicvtec
May 2, 2005 12:34 AM
