Anti-Sway bars
my car is an EX with stock front sway....so the front will bolt up but will i have to change anything in the rear to get the rear sway to bolt up? i would like to avoid having to replace my rear LCAs
ORIGINAL: riceburner700
if your car doenst have sway bars and say you buy front and rears with bushings do you have to get anything else or will they bolt right up to my cx?
ORIGINAL: Savatage
ORIGINAL: Savatage
yeah 96-00 civic have holes already for the rear sway bar. no need to change the LCA. all you need is the sway bar, d-brackets, and endlinks.
on 6th gen cars if you install a large rear sway bar you should get a subframe reinforcement kit. I have seen sway bars as small as 13mm tear out the subframe where the sway bar mounts. Some insurance companies will declare the car totaled because of it. The Si came with reinforcements from the factory. And all 6th gen have the hole in the LCA's for sway bars
slivergun
Apr 28, 2007 01:30 PM
mybrokenblinker
18
Mar 19, 2007 02:34 AM
civicstealth
May 8, 2006 08:20 PM
