brake pads
Old Aug 30, 2006 | 12:30 AM
civic_vtec_SiR's Avatar
Default brake pads
hey everyone.
i know this is a real noob question lol, but whats the best way to tell if my brake pads needs replacing? latly they have been squeakking quite a lot especially wen first driving. ive got a eg9 if that makes any difference.
cheers
Andrew
Old Sep 3, 2006 | 08:50 PM
mousetopher's Avatar
Default RE: brake pads
if the friction material is thin (a couple mm) then you need new pads. most likely the pads are semi metallic which could be your noise. or it could be a pad wear indicator. when you check pad thickness, check ALL of the pads. sometimes the inner pads wear faster than the outers.
Old Sep 3, 2006 | 11:46 PM
AgentofDarkness's Avatar
Take off the wheel. Look at the caliper, there is a little hole in the middle of the caliper that will allow you to look at the pads w/o removing the caliper. If it looks like there is little friction material it is time for new pads.
j2performance
Jan 15, 2008 01:48 PM
asdfasdfdasfasdf
Feb 13, 2006 07:03 PM
AgentofDarkness
Jan 24, 2006 12:34 AM
dc5pro
Jul 1, 2004 10:57 AM
dc5pro
