Brake problem
Having a little trouble like usual on my 97 civic ex. I did my front brakes couple weeks ago everything turned out real good. Just finished my back brakes today and every time i go to stop it feels like my pedals pumping and theres a loud clunking noise from the back.I have done backdrum brakes on every car i have ownedim pretty sure i did everything 100% right i go by the hanes manual. Any suggestions on what it could be or enything?
my rear brakes are doing that as well when i let it sit over night... not sure what it is. The front brakes are also doing some weird stuff now as well... i really need to go see a professional [X(]
try going to get a brake inspection at a certified mechanic... that should help (although it will cost $100-$200)
if ur used the right shoes/drums and everything is actually installed correctly, there shouldnt be any problems. i did my shoes/drums a little while back and its been doing great. all i can say is double check the spring clips, springs, cables, arms, shoes, cylinder, drums, adjuster, re-grease, etc..
Blah i took Both sides apart and went over them today. In the end its still doing it i even bled the whole system out. Im positive its all the right stuff. at hig speeds when i come to s top it doesnt do it bt low speeds its real bad.
Is there a possibilty maybe they gave me the wrong shoes. Maybe shoes for civic dx or somethingor would there not be a diffrence enyways? Im 100% sure there installed correctly and its getting real annoying.
Ed Fisher
Aug 20, 2009 11:47 AM
Cosworth
Dec 15, 2008 05:35 AM
burgernuds
18
Aug 16, 2008 07:20 PM
j2performance
Jan 15, 2008 01:48 PM
