brakes
my left brake caliper had stuck on against the wheel (front left) so i took the caliper off and the piston was stuck so i took it apart and it seemed to work fine. so i put it back on the car and changed the brake fluid but now the pedal travels all the way to the bottom before i get any braking force. can ne 1 suggest y.
You have to bleed your brakes. You need another person the press the brake while you bleed it. Check out the D.I.Y. for brake bleeding. If there isn't something there google search it. I would explain the process but I'm not good at describing how. It's relatively easy though.
Good luck.
Good luck.
jonsaidthat
May 30, 2010 09:30 PM
ahhsimon
Jun 14, 2006 09:52 AM
