Bushing help please
Old Jun 16, 2006 | 03:25 PM
CXsleeper's Avatar
Default Bushing help please
I am going to replace the bushings in my car when i change out the suspension pieces. the problem I think I am going to run into is that I am also changing some of the control arms.
ITR fornt lower control arm with ITR sway bar, 88 crx rear LCA.
Do I need to buy the control arm bushing kit for the ITR, CRX and Civic to get all the bushings I need?
Also I have seen that there are shock specific bushings also IE Tokico Shock bushing kit. Should I get that instead of the factory honda shock bushing kit.
This is for my 92 HB
Old Jun 16, 2006 | 03:31 PM
ef4life's Avatar
Default RE: Bushing help please
the integra and civic pieces should interchange, why use 88 crx lca's are you going to use type r shock? there is a lot more availability for aftermarket shocks if you keep your stock lca's, but they are 2 ibs heavier than the 88's
Old Jun 16, 2006 | 05:37 PM
CXsleeper's Avatar
Yah I am going with the 88 LCA cuz its a little bit stronger and using a type-r type mount shock. I am going with Tokico Illuminas so I have my shocks picked out already.
Thanks.
Mecca8383
Apr 17, 2011 07:54 PM
justin07731
12
Sep 13, 2009 05:02 PM
addiction2bass
Oct 24, 2007 05:07 PM
honda_farmboy
Jul 16, 2007 01:44 PM
rsboy
Jul 16, 2007 11:28 AM
