Change rims
So i change rims on my car and now my steering wheel moves alot so i put back my old wheels but it still does the same and when i drive my car go to the side so i have to grab my steering wheel harder...why did this happen and what can i do to fix it?
i can think of three possible reasons
1. your car is out of alignment which is probably the most likely
2. your wheels need balanced
3. for some reason you didnt tighten the lugs properly or not enough, but i think that by switching back to your old ones that wouldnt be it.
If its not this stuff then its a suspension problem
so your cars pulling... that would be alignment issue
or if its vibrating... either balance the wheels or you didng torque down the wheels properly o rmaybe used the wrong lug nuts and the inside tip is not seating properly flat.
well vibrating is more tire ballance....
did you properly tighten the wheels? torqueing them down properly side to side.... not just tightening one all the way tight and then doing the next.... just an idea... if its just vibrating then id vote to get the wheels ballanced.
Always use a torque wrench and torque specs when tightening nuts and bolts. Always tighten and loosen lugs in a gradual criss-cross pattern too. Finger-tighten in criss-cross, then torque them with the torque wrench, only torquing each fastener a bit at a time before moving on to the next. You basically don't want any one lug torqued much tighter or looser than the others.
if the steering wheel is vibrating, its most likely the wheels are out of balance. if it vibrates only when braking, then the rotors are warped. but since u said this started happening when you put your old wheels on, its highly likely they just need to be rebalanced.
txedomask433
12
Jul 15, 2007 01:57 PM
mahmi
Aug 4, 2005 04:24 PM
