vibrations suddenly at high speeds
Old Jan 2, 2009 | 08:12 PM
zotar20's Avatar
Default vibrations suddenly at high speeds
i drive a 97 honda civic with 135K miles on it. i just had my rear brakes replaced and noticed after picking it up that vibration occurred throughout the entire front end of the car at 65+ miles. this was not happening before I got my brakes fixed. the mechanic also did an alignment after replacing the brakes. not sure why the vibration is now occuring, but is it purely coincidential and can be explained by something else or related to the repair work i had done? what could be responsible for it?
Old Jan 2, 2009 | 09:24 PM
conceptualpolymer's Avatar
Default The shop is the prime suspect.
I would've turned around as conveniently as possible after I felt the vibration and went back to the shop. A vibration like that can be caused by something as simple as a wheel weight that fell off the wheel, or it could be because a suspension component loosened or was not properly tightened when the alignment was done.
My advice? Get the car back to the shop, ASAP!
Old Jan 3, 2009 | 06:32 AM
kanarrjl's Avatar
it could of been an accident but if you don't know them well then it may have been on purpose to get you to come back and spend more money
Old Jan 3, 2009 | 12:17 PM
Were the tires rotated? This problem is almost always caused by a wheel(s) out of balance. Have all four wheels properly balanced.
Clean_Civic_98
Dec 30, 2009 09:27 PM
alexsi
Sep 8, 2008 06:08 PM
HiddenShadow
Jul 8, 2007 02:36 PM
phsballer123
Jun 9, 2007 12:17 AM
MOONRAKER
Aug 8, 2006 10:37 AM
