Cleaning Mistake....
Old Mar 1, 2007 | 12:06 PM
CivicSi45's Avatar
Default Cleaning Mistake....
ok i was doin some cleaning yesterday on my car cause the guy i bought it from i guess like hit a nasty dirt puddle and sent a **** load of mud into the engine bay cause theres dirt spots all over the engine bay and on the bottom (inside) of the hood, and i was cleaning it and then i took the stock tie bar (upper strut bar?)or what ever it is, off to re paint it to give it a clean lookand now i can't figure out how to get it back on. Was i not suppose to take it off, i have the 00' si so im figuring it was the stock bar cause he said everything on it was stock when i bought it from him, so was that not supposeto be removed if i wanted to get it back on. Any advise on HOW to get it back on...
i already feel really dumb so i hope i don't get picked on for this, lol
Old Mar 1, 2007 | 12:31 PM
mxs's Avatar
mxs
Default RE: Cleaning Mistake....
um. what do you mean, it won't go on?
if the holes won't line up, try jacking up the car in the middle, that will let the chassis flex some and you should be able to wrestle it on over the studs
Old Mar 1, 2007 | 06:46 PM
CivicSi45's Avatar
well that the thing, the studs wont go into the holes, it seem like went they put the car together they had the bar placed over the holes (on the camber tower if thats what it is) and then screwed the studs in ...idk, it just seems like its impossible to get on unless i can go from the bottom and unscrew the bolts out and put the bar in place and put the screws back in...ahhh...whatevaa
Old Mar 1, 2007 | 10:18 PM
mybrokenblinker's Avatar
if its possible to get off, its possible to get on
Old Mar 1, 2007 | 10:50 PM
mxs's Avatar
mxs
yeah, try doing what I suggested above. maybe try getting one side on first, then the other.
Old Mar 2, 2007 | 04:00 PM
CivicSi45's Avatar
i did, and that was the closest to get on but its still not budgen...im a lil worried...oh well. Ima take to to one of my local shops i go to, to see if they know what to do...uuhggg
jake11375
May 10, 2009 07:49 PM
ic892003
Dec 24, 2006 08:52 PM
ph3n1x
Nov 1, 2006 07:03 AM
Remmy
Oct 20, 2005 07:25 PM
