Is this correct?
Old Sep 17, 2007 | 03:36 PM
Revn7's Avatar
Default Is this correct?
I'm getting the stuff for the rear disc conv. and I got the porportioning valve for free. I just want to make sure its the right one. on the link for the diy it shows the same valve thats on my car now. is the stock one correct also?
[IMG]local://upfiles/22068/58C8458984E04416B098D295BD8B9FD7.jpg[/IMG]
[IMG]local://upfiles/22068/B43AA3C7306E4EFCAB9D6D38EDF6C2E0.jpg[/IMG]
Old Sep 17, 2007 | 05:25 PM
Strong Island's Avatar
Default RE: Is this correct?
you can just leave the stock porportioning valve on, but id rather myself change it to the 40/40 valve out of Tegs...im running rear disks now for like 1 month with stock im guessing 40/30 proportioning valve and booster...ill eventually get around to buying the right parts lol but for now its fine.
Old Sep 17, 2007 | 08:09 PM
danomatic93's Avatar
June 2010 ROTM
Here's a "what you may or may not need" list FOR 92-95 (other models may apply):
Calipers - rebuild if used ($6+ each), buy rebuilds if can't rebuild ($65+ each)
Brake pads - replace to be safe ($25+)
Rotors - resurface ($50+ set ) or replace ($90+ set)
Brake hoses - disc have different hose, they attach w/banjo bolt instead ($32+ each)
Trailing arms with disc- paint if needed ($20+ each, you may get luckier at junk yards)
E-brake cables - keep attached to the trailing arm, it makes things SOOOO much easier
Trailing arm bushings - inspect and replace if needed. ($80+)
How to: http://www.honda-tech.com/zerothread?id=1589298
Proportioning Valve - if you have a EX you can get away w/keeping the 3040 BUT replace with a 94-01 Integra 4040 P-valve NON-ABS asap. ($30 eBay!)
Brake booster and Master Cylinder - from integra, this I've heard is optional, but highly recommended. ($10+ junk yards)
Brake fluid - DOT 3, get the BIG bottle ($6+)
Here are some links for resources:
http://hondacrx881.tripod.com/discbrakes.html
http://www.automotiveforums.com/vbulletin/t525526.html
http://www.diynetwork.com/diy/ab_bra...275324,00.html
http://www.civicforums.com/forums/43...elled-out.html
http://www.hazone.com/hdiscswap.htm
Old Sep 17, 2007 | 08:22 PM
Sigracer10's Avatar
heres a really good site for doing the conversion on an ek. theres a list of parts needed on the site.
Old Sep 19, 2007 | 05:53 AM
Revn7's Avatar
wow thanks for all those sites. I forgot to mention i have a 00 ex and the porp valve came off of a del sol drum. not sure the ratio but it was free so no loss if it is wrong. here is what i have.
[IMG]local://upfiles/22068/C09F9F9E93A7435A856C74F16F8D7C36.jpg[/IMG]
tlkolrod
Nov 25, 2006 01:14 PM
briandors
Nov 6, 2006 08:41 AM
02CivicEX
Jul 19, 2006 10:35 PM
audiophile
Jun 5, 2006 09:10 PM
Amanda
Feb 25, 2005 07:15 PM
