found camber wear on my tires
hey guys, just rotated my tires today. found some inside camber wear on my tires. i pulled the washer trick for the rear wheels. but i was wondering if there was a trick for the front of the car? i dont have a camber kit. and i have Tein S tech's, so my drop is nearly two inches. thnx for the help.
with two inches, you're going to wear tires pretty quick regardless. but if you haven't had an alignment since you lowered it, then that's your problem. toe affects tire wear more so than camber. and no, the front suspension is not adjustable.
Rico
Jan 18, 2008 07:06 AM
dblclutchin
14
Feb 25, 2007 12:39 PM
