Help an old friend out
Old May 25, 2009 | 04:01 PM
Pete's Avatar
Default Help an old friend out
Hey.
Got some shaking going on in the steering wheel and petals while the engine is under load. Mostly when im in 5th gear at 65-70 mph and accelerating. I figured tire balance. The tires were shot so I got new ones, and had an alignment done after. Helped a little. Struts are all new. Now that I look at the front motor mount (drivers side) it looks a little worn and there is slight play front and backward. Could this be the culprit? How much are these things supposed to move front to back? The front mount was from an integra, so it was used. The side mount is a hasport, so it def wont need replacement.
Old May 25, 2009 | 05:08 PM
Did you get all four wheels balanced? One time, I had to bring my car back three times for bad wheel balancing, and they still didn't get it right. Found a better mechanic who nailed it perfectly the first time. I wrote a letter to the area supervisor of the "bad" shop. He refunded my money and also paid for the good balance done by the second "good" mechanic.
Anyway, I wouldn't think that even a completely shot front mount would cause the vibration you are describing. How do the rear and transmission mounts look?
Another possibility would be a bad axle.
Old May 25, 2009 | 05:30 PM
plethoric33's Avatar
Id say check out the axles and all suspension components. Even though the struts are new, something may have bee sitting funny when torqued down and allow for movement now.
Old May 26, 2009 | 12:29 PM
Pete's Avatar
Well the thing is that when I am in 5th gear going 75 and accelerating it shakes, if I push the clutch in it all goes away and coasts smooth as can be.
Old May 26, 2009 | 01:46 PM
This sounds like a bad axle to me, especially if all but the front driver's mount are fine.
Old May 29, 2009 | 02:18 PM
Pete's Avatar
I just dont see how it would roll smoothly when in Neutral. The tie rods were all replaced. I just dont have the time to try and troubleshoot everything. Might let my mech look at it for a free consultation.
Old May 29, 2009 | 08:08 PM
If its riding smooth while in neutral, then Im going to say the mounts must be worse than you can really see, or they are not properly torqued down. I couldnt see any suspension parts only acting up while on the gas.
Old May 29, 2009 | 08:27 PM
I think a bad axle would vibrate most if not exclusively under load, such as when accelerating.
Old May 29, 2009 | 08:36 PM
ej6buddy's Avatar
It sounds like a bad axle to me as well. Has it been checked for any loose play or side motion? Sometimes the vibration isn't noticeable until a certain vibration frequency (such as on the interstate). And does your steering wheel itself have any play in it? Sometimes it's the steering system itself if the car has many miles because the forces acting on it are greater at higher speeds. have power steering?
Old May 30, 2009 | 06:37 AM
My bad axle vibrated all the time. Unless he has happened to notice his going bad at is beginning stages.
lolitha
May 9, 2008 12:02 AM
KTeacher07
Mar 4, 2008 03:37 PM
kokasian
Nov 21, 2007 01:55 PM
POLYTHING
Mar 16, 2007 07:04 PM
Kei
Nov 25, 2006 04:08 PM
