How do I change front pads, 2000 Civic LX
Old Jul 19, 2007 | 04:54 AM
osu6speed's Avatar
Default How do I change front pads, 2000 Civic LX
I need to change the front pads and maybe the rotors on my daughters 2000 Civic LX 4 dr. How difficult is it to do. I haven't done my own brake work in almost 30 years, but I want to start doing it again. Are there any sites that would have photos on how to do it?
Thanks for the help.
Old Jul 19, 2007 | 10:11 AM
BlackEM1's Avatar
Member
Default RE: How do I change front pads, 2000 Civic LX
1. Pull rim off.
2. The brake caliper should be on the front of the rotor, there are two bolts on the backside, pull them out. (I want to say they're 12 mm bolts)
3. Pull caliper off the rotor.
4. While you have it off, your brake piston will push out, using your old pads push them in. I can do this without a C Clamp, but if you use a C Clamp, you'll need a 4-4.5" clamp. Make sure to push it in straight, if the piston gets cockeyed it'll cause locked brakes or uneven pad wear.
5. Once the piston is pushed back in, put the new pads in the caliper.
6. Remount caliper to rotor.
7. remount tire.
8. Drive around braking properly to wear pads in.
Old Jul 19, 2007 | 10:30 AM
osu6speed's Avatar
Thanks for the reply. There are no clips that need to be removed / replaced when I change pads?
Old Jul 19, 2007 | 10:43 AM
mybrokenblinker's Avatar
I did this yesterday...well tried, i had the wrong pads and had to put it all back together and send the pads back for ones of the right size. You only need to do the bottom bolt, and then the caliper will swing up on the top bolt and you can access the pads.
Old Jul 19, 2007 | 11:25 AM
BlackEM1's Avatar
Member
ORIGINAL: osu6speed
Not that I'm aware of. I've done my brakes all around several times now. I had a bad caliper on my rear, so I got more into it than I ever wanted to.
As far as just taking off the bottom bolt. It's easiest to remove the caliper so it's off the bracket over the rotor for easiest access to the pads.. since it's just two bolts, it'll be easiest in the long run.
Old Aug 9, 2007 | 04:03 PM
tl12356's Avatar
Good idea to remove caliper totally,(both bolts),so you can inspect everything and clean all the dust as well.
Also give you time to check the bushings on the bolts for wear and lubrication.
Hope this helps...
justgot2run
Jul 3, 2008 04:45 AM
vltnolia
Jun 20, 2008 06:44 PM
j2performance
Jan 25, 2008 09:40 AM
bkr123
Sep 29, 2006 05:31 PM
ewalberg
Nov 22, 2004 11:18 PM
