How Low?
your best bet is to go with adjust springs.My biggest problem though is my front of my body kit,if you drive in reverse my front will get stuck it will pull the front off.My friends got an acura intg and his car when he got it was always bottoming out luckly he had adjust springs and we truned them a notch problem solved.
ORIGINAL: mill$civic
sounds good torga3ight...im getting my rims in about 2 weeks and there 205/40/17 and i have the s-techs on right now so from what you say i should be good
yea on my hatch in lowered about 3 inches all around with areospeed adjustables and blue tokicos with 17's. The fender is tucking the tire maybe little less than 1/2 an inch and the back is just right above the tire. It doesn't do to bad just when i go around tight corners and if there is a pretty bad dip in the road but other than that its fine. If i were you i would go with TorGa3iGhT idea sounds good.
sebdiz
Apr 28, 2010 05:45 PM
boostphreak
Aug 27, 2008 11:15 AM
liliechen
Dec 25, 2005 11:15 AM
