intermitent brake pedal to the floor... HELP!
Old Feb 29, 2008 | 08:58 AM
kbeezy13's Avatar
Default intermitent brake pedal to the floor... HELP!
please someone help me with this, after i make an abrupt change of direction (sharp turn, or forward to reverse) my pedal will go to the floor, but only once then it pumps right back up. my first thought air in the lines or master cylinder. bled all the lines, rr-lf-lr-rf in that order, still does it. replaced the master cylinder... still does it! does anyone know anything please help!!! i just spent $1900 on a whole new front end cause it was wrecked i don't wanna wreck it again!
Old Feb 29, 2008 | 10:42 AM
bakertime's Avatar
Default RE: intermitent brake pedal to the floor... HELP!
First of all, DON'T DRIVE IT...under ANY circumstance. You're putting your own life and others at risk.
Look around for vacuum lines that might be busted. I'm not sure, but you may have a bad MC or Booster. The only thing I can think of that would be caused by direction changes would be not enough fluid, or something being pinched by a moving part while turning (although I highly doubt that).
Old Feb 29, 2008 | 01:11 PM
kbeezy13's Avatar
solved my own problem, earlier this week i did my clutch and my buddy put some lowering springs on while i was swapin the clutch. he put the front struts on backwards, so the clearance for the axle on the strut fork was facing outwards, every time i turned the wheel the fork was pushing my caliper away from my rotor. swaped them around and no more problems...
Old Mar 1, 2008 | 06:39 AM
bakertime's Avatar
Wow...strange. Directions FTW!
vwhater
Jun 27, 2016 06:04 PM
tim.ocallag
12
Aug 5, 2011 06:16 PM
Mecca8383
May 8, 2010 03:10 PM
HondaJohn
12
May 23, 2007 04:16 PM
cbrandes
Feb 15, 2007 01:00 PM
