LCA Bushing Replacement
Old Mar 16, 2008 | 12:49 PM
biggn's Avatar
Default LCA Bushing Replacement
I am trying to replace my front LCA bushings. I have read the DIY's on a couple of sites and felt confident I could do this. It is a 93 civic coupe. The forward pivot bushing has been cut out and i have cut through the sleeve 4 times now so it is in quarters. I t still will not come out. I have tried to chisel it out... the soft metal just shears away... Anyway I was just wondering if anyone else has had major problems getting these sleeves out.
Old Mar 16, 2008 | 12:54 PM
Default RE: LCA Bushing Replacement
try using a socket just a hair smaller than the hole (so about the same size as the sleeze) and a hammer. It's how I got the sleeves out of my rear LCAs
It's ghetto but it works.
Oh yeah, I almost forgot... find something to put the lca on while you're hammering so the sleeve can just drop out the bottom of the lca. Otherwise, I doubt it'll come out easy.
Old Mar 16, 2008 | 02:24 PM
civicexracer's Avatar
did u cut the sleeve all the way thru? one cut all the way thru the sleeve should be enough to get it out. when i did it, the first couple sleeves were tough to get out cuz i didnt saw thru the sleeves enough, even when making a couple cuts. after that i cut completely thru the sleeve, even nicked the actual arm itself just a bit, and they practically fell out..
Blue_Rocket_WRX_STi
Sep 17, 2009 03:17 PM
97blackhonda
Jun 14, 2009 06:47 PM
reaper2022
Suspension & Steering DIYs
Dec 29, 2007 05:24 PM
Fiirkan
Nov 27, 2007 11:37 AM
snosurfa7
13
May 18, 2007 02:08 PM
