are lowering springs good enough?
Old Dec 5, 2007 | 05:16 PM
civicexracer's Avatar
Default RE: are lowering springs good enough?
if ur gena lower ur car about 2", get some decent aftermarket shocks. esp if ur still on original 12yr old shocks.
Old Dec 5, 2007 | 06:28 PM
hiroshi's Avatar
Member
well then, i guess i'll check out some eibach shocks then.
Old Dec 5, 2007 | 06:33 PM
mxs's Avatar
mxs
ORIGINAL: reaper2022
(I haven't heard of any problems with the upper/lower lca bolts).
ALL the LCA bolts can get stuck. (there's no such thing as an upper LCA bolt) When they get stuck, the problem is not just the bolt, but the bushing that it's seized in... if you want to be REALLY prepared you get new LCAs or new bushings before you start.
Old Dec 6, 2007 | 03:38 PM
^ I meant the bolts on the ends of the LCA's... and I've never really heard of anybody having problems with them (that's not to say it never happens). I ended up replacing all the bolts and bushings in the LCA's anyway... and +1 on the "all the bolts/bushings" thing... it's an extra $60 or so to tack onto the total cost of the suspension work.
Old Dec 6, 2007 | 06:13 PM
mxs's Avatar
mxs
Both of mine were seized on my Civic.
Old Dec 6, 2007 | 09:59 PM
91crx_97cx's Avatar
i found out that mine were to when i had to replace my passenger side LCA when it snaped
Old Dec 7, 2007 | 06:25 AM
hiroshi's Avatar
Member
ok, complete noob question. what is a LCA? thanks in advance.
Old Dec 7, 2007 | 11:14 AM
Civic Dx 349's Avatar
Member
LCA=Lower control arm. Aka,the armthat the bottom of your strut mounts to.
Old Dec 7, 2007 | 01:55 PM
ORIGINAL: mxs
I stand corrected. I guess nobody ever complains about it... all I ever hear is about the shock-mount bolt/bushing seizing up.
anyways LCA's are these gizmos circled in red:
Scott53092
Sep 13, 2009 03:32 PM
Civiclover07
Oct 26, 2008 02:52 PM
06Civ
Nov 28, 2005 01:04 PM
ngoti 8tor
Oct 17, 2005 10:18 AM
