Lowering, suspension question
Old Sep 8, 2007 | 08:28 AM
Chester99civicEX's Avatar
Default Lowering, suspension question
Ok, so basically I do not know the slightest thing about what to do about suspension on a car, I read all of the suspension info that was posted on the "links to useful suspension info" thread but still am highly confused. After reading other threads i see a lot of people reccomending Tein S-tech springs to lower a car. I have a '99 Civic EX and just want it lowered enough to look good with 16" rims and 205/40 tires. Are the springs all i need? or do i need any other parts to do this. I want to do it right the first time so I am willing to spend extra to get it done right. I rarely race the car, so i am basically just looking for something to help on the street rather than the track.
Thanks guys
Old Sep 8, 2007 | 08:37 AM
Default RE: Lowering, suspension question
you can get away with just getting the S-techs. However, it's probably a good idea to get new shocks since shorter springs will tend to blow out your stock shocks eventually. Also, you'll probably want new rear Lower Control Arm (LCA) bolts, since there's probably about a 90% chance that your stock LCA bolts will be completely seized and break when you try to remove them.
Old Sep 8, 2007 | 10:07 AM
Everyday Getaway's Avatar
ORIGINAL: reaper2022
Yup... learned that the hard way! You should definatly go with new shocks AND springs because they'll last you a lot longer and you'll feel a dramatic differnece in the cars handling over stock. I have thetokico HP spring and shock set for 92-00 civic's, which I think is the cheapest set out there (usually about $400 shipped)and they're fantastic, check this site, they're prices are pretty fair http://robearracing.com/cat_suspension3.cfm.
addiction2bass
Mar 26, 2009 11:09 AM
icecoldstar
Jun 1, 2008 12:37 PM
rags2richs
Nov 16, 2007 12:48 PM
bakertime
Oct 19, 2006 01:09 PM
milner993
Sep 19, 2006 05:38 PM
