master cylinder?
Old Jan 29, 2009 | 05:47 PM
midnight_96civic's Avatar
Default master cylinder?
my friend has a 96 probe gt 5 spd. he is stupid and put power steering fluid in the brake fluid reservoir which is also the clutch reservoir on that car. would the power steering fluid cause the master cylinder to go out? we replaced the slave cylinder and bled the lines and when the car is running the brakes and clutch go to the floor with barely any effort and the clutch will not engage. there was no signs of clutch wear and the car will not go into gear. if its not the master cylinder what could it be?
Old Jan 29, 2009 | 05:54 PM
I recommend that you first bleed the system more. A small amount of air will cause a hydraulic system to malfunction. For Civics, the wheels must be bled in a specific order. Start by bleeding components farthest from the master cylinder. Did you bleed the slave cylinder?
sway2003
Dec 27, 2006 07:33 PM
campbuds
Jul 10, 2006 10:54 AM
Dogmeat
Feb 3, 2006 10:38 PM
StifflersMom
Nov 9, 2005 01:39 PM
jcclow
Jan 21, 2005 09:36 PM
