need help with lowering
Old Sep 14, 2009 | 03:52 AM
nbatge's Avatar
Default need help with lowering
hey, new to the forum and had a question about lowering a civic.
How do u lower a civic and does it cost much to get a pro to do it and is this all i need to lower it?
heres to link: http://cgi.ebay.com.au/COILOVER-SPRI...d=p3286.c0.m14
looking to hear for u
cheers
Old Sep 14, 2009 | 01:05 PM
hamorhead's Avatar
no
how you do it is either cut your stock springs or if you wanna go really low you can just remove them all together that way you can be slammed and it cheap
or you could try this- https://www.hondacivicforum.com/foru...ad.php?t=49092
Old Sep 14, 2009 | 06:04 PM
you get what you pay for!!!! ebay cheap *** lowering kit... CRAP!!!! it will ride like a big turd and blow your stock struts.
the most recomended coilover setup for a 92-00 civic is koni yellow struts and ground control coilovers. both high quality parts that will last a long time and take the abuse you throw at it! camber kit isnt really needed but defiantly make it look better. but main thing is if you EVER change your suspension or coilover adjustment perches. YOU NEED TO GET A 4 WHEEL ALIGNMENT. OTHERWISE your tires will have the inner thread just eatten away FAST!!!! most newbies call it camber wear since there tires are angled in without the camber kit. but toe is whats killing the tires!
Old Sep 15, 2009 | 03:13 AM
nbatge's Avatar
thanks for your reply's. addiction2bass thank for the info, could u give me a link on what to buy or any good brands to look at.
cheers
Old Sep 15, 2009 | 03:20 PM
well the ground controls you can buy directly from them...
http://www.ground-control-store.com/...egory.php/CA=5
and i have a set of koni yellows slightly used for sale.
the ground controls are ruffly 300-400brand new, and the koni yellows are ruffly 500-700 brand new.
chasemclemore
Mar 26, 2009 02:08 PM
bobackwards
Aug 9, 2008 02:38 PM
Hotsawce97
Nov 24, 2007 09:26 AM
rrinaz32
17
Oct 14, 2007 09:54 AM
JerZy
Feb 19, 2007 08:57 PM
