Need help with shocks
well i finished my search for shocks and springs, and i found some tokico illuminas adjustable shocks, with tokico 1.5 dropped springs. i also bought some MUGGEN Strut bars for the front and back. do you suggest any other things i should buy for good shock performance?.
do the shocks come with new strut dust boots?
if not, i recommend getting some KYB ones from tirerack.com
the stock ones tend to squeak on lowered cars.
KYB ones aren't too expensive
how important are those strut boots on my suspension?
i've been reading alot ABOUT camper kits, toe in, toe out, caster and all this other crap. but its very good and useful info. now, i dont want my tires to wear out fast, and supposedly when you lower a car, the stock camber f***s up and needs to be replaced.
1- ANY AMOUNT OF LOWERING WILL AFFECT CAMBER IN THE NEGATIVE DIRECTION.
2- THE CAMBER WILL NOT RESULT IN EXCESS TIRE WEAR BUT WILL RESULT IN ALIGNMENT ANGLES WHICH ARE NOT IDEAL OR ARE OUT OF SPEC. THE CAMBER WILL LIKELY BE VISUALLY APPARENT.
3- THE ONLY WAY TO FIX NEGATIVE CAMBER ON HONDA/ACURA VEHICLES IS WITH A CAMBER KIT.
but they say also that camber kit is not necessary only a good *** alignment. now WHICH ONE IS IT??????
For Hondas, a camber kit is a debatable issue. When you lower the car, the camber will go out and you need a camber kit to fix it. However, I find it is not necessary to correct the camber in most cases. Most people think they need a camber kit because of a tire-wear concern. The reality is, TOE ANGLE kills tires WAY faster than camber ever will.
Well, there is another adjustment/spec here than nobody has mentioned. Caster is another key. Caster is great for high speed stability. That is why all cars have some dialed in. Without it, the car would be super twitchy and hard to control at speed. It's why autobahn burners have more caster than your typical Japanese car.
The problem is, when you lower the car and toe angle is thrown out, the wheels are actually riding on the inside edges of the tire as they grind away pulling the car in different directions! This is in addition to the increased camber effect! With an improper alignment the car will WASTE tires in a matter of months.
The trick to lowering the car and having the tires last is to get a good 4-wheel alignment to fix the toe angle
bgaccord
Feb 25, 2009 06:58 PM
spintelect
May 17, 2007 04:23 PM
secondhandloser
Apr 28, 2007 09:33 PM
kimsuprapa
Sep 11, 2006 12:57 PM
