Need a huge favour
Old Oct 2, 2007 | 07:32 AM
DaRKoN's Avatar
Default Need a huge favour
Hi guys, If possible I would really appreciate a guide on removing lower control arms,replacing ball joint, replacing sway bar links. All the Do's and Don'ts.
Old Oct 2, 2007 | 07:50 AM
Marty's Avatar
Default RE: Need a huge favour
Buy a haynes or chiltons manual as it will guide you through the whole thing step by step
Old Oct 2, 2007 | 08:10 AM
mxs's Avatar
mxs
I haven't done ball joints, but the other two are extremely straightforward. Get good tools, remove, replace, and torque to factory spec. I can't give you more specific details because you didn't say what car you have
Old Oct 2, 2007 | 09:37 AM
DaRKoN's Avatar
my car is a 97 civic coupe. The lower control arms are in what looks like two pieces that are bolted together by two bolts. The sway bar links bothe the two arms together. I just want to know if there are any precautions to take when removing parts, especially in the brake and steering area.
Old Oct 2, 2007 | 09:48 AM
mxs's Avatar
mxs
Don't try to take the lower control arm apart. It will come out in one piece.
Old Oct 2, 2007 | 09:50 AM
mxs's Avatar
mxs
Remove the 8/9 bracket, and take it out with the 7 bushing still attached to the arm
Old Oct 2, 2007 | 10:05 AM
DaRKoN's Avatar
thanks alot, apreciate the quick responses.
Old Oct 6, 2007 | 04:18 PM
DaRKoN's Avatar
Ok. i got the job finished but no the car is drifting to the right. Did I miss something or do I need and alignment?
Chaos
May 23, 2007 12:18 PM
Pete
Sep 10, 2005 05:07 PM
LEVIII
Jun 21, 2005 12:43 PM
JDMB16CIVIC
Oct 28, 2004 06:34 PM
