Rim Size/Offset Question
Old Oct 24, 2008 | 10:59 PM
bcrichguitars's Avatar
Default Rim Size/Offset Question
Will 16x7 Enkei FN-18 wheels with +42mm offset? I was thinking this would be a better offset than my current setup. I currently have 14" Volks with probably an offset between +35mm and +37mm and Tein Coilovers. The wheels are pretty close to rubbing on the outside of the fender and the car is pretty low. Will the Enkei's fit with a 205/40R16 tire and do you think the 42+ offset is going to run on the inside of wheel well?
Old Oct 25, 2008 | 01:29 AM
That should fit fine. I'm pretty sure 40 offset is what you'd want optimally, but 42 will be close enough.
Here's a tire size comparison between stock and this:
Old Oct 26, 2008 | 07:39 AM
A +42 offset with 7" wide wheels should fit just fine. Actually, it's a pretty ideal offset for 7" wide wheels on EGs; I was tucking tire with my 17x7's with +45mm offsets with no rubbing.
Old Oct 28, 2008 | 05:32 PM
KarTuneMan's Avatar
Cool
I second reaper2022 ....
rhoades513
Feb 6, 2012 12:26 PM
Lambo Civic
Oct 26, 2010 01:38 PM
DNkG
Apr 9, 2009 05:48 PM
ninetysevencivic
Oct 27, 2006 02:23 AM
rok_spitfighter
Oct 20, 2006 10:35 AM
