riml/tire size
Old Jan 6, 2008 | 10:20 AM
Hawley's Avatar
Default riml/tire size
I'm thinking about purcasing a 98 EX Civic Coupe with 115,000 miles on it. I was thinking of putting 16" rims with 225/45 tiresfrom tirerack.com. This is the only mod I at first. Also, what do I need to look for to make sure the car is not a "lemon" and when does it need the timing belt replaced. If soon, how much will it cost. Thanks in advance !!!
Old Jan 6, 2008 | 10:35 AM
magic_mohawk's Avatar
Default RE: riml/tire size
I'll just let you know that your probably going to rub that size of tires. I have a 92 Civic Hatch that has 225/50/15s and they rubbed. I had to stick some spring spacers in to fix it, but now my suspension is stiffer in the back. Just some FYI.
Old Jan 6, 2008 | 12:50 PM
Civic Si 00's Avatar
There too wide. They will rub like magic_mohawk stated. 225/45 bad IDEA >>> Go with the 205/45 and you should be fine they will tuck in real good and you won't have to worry of hitting the fenders or rubbing them on dips, bumps etc.....
Old Jan 6, 2008 | 03:50 PM
mxs's Avatar
mxs
205/45/16 would be the right size to get
Old Jan 6, 2008 | 06:54 PM
BillyB98's Avatar
^+1 to mxs
ballplaya4eva07
May 26, 2005 06:28 AM
fastman90
Apr 22, 2005 03:23 PM
INJENalltheway
Dec 28, 2004 08:06 PM
jablalock06
Nov 19, 2004 04:05 PM
zaidomar
Nov 17, 2004 01:06 PM
