Rotor Removal
Old Nov 8, 2006 | 11:11 PM
D16z6's Avatar
Default Rotor Removal
Whats will happend if I removed the front rotor? I know it will have to be turned on the car but I wanna replace it.
Old Nov 8, 2006 | 11:32 PM
mxs's Avatar
mxs
Default RE: Rotor Removal
I'm not sure what you're asking? yes, you can get them turned, or you can replace them.
Old Nov 8, 2006 | 11:45 PM
D16z6's Avatar
I mean they are pressed on so don't you have to like removed the hub assembly?
Old Nov 9, 2006 | 12:11 PM
HARI.'s Avatar
no you don't need to remove the hub assembly. just take the brake calipers and bracket off, and take the 2 screws off, and it should come off
Old Nov 9, 2006 | 02:27 PM
civicexracer's Avatar
ya, might take a couple wacks with a mallet to break the rust tho
Old Nov 9, 2006 | 05:40 PM
D16z6's Avatar
So pretty much removed caliper, removed two screws then just pull it off? Nothing special like the accord?
Old Nov 9, 2006 | 05:41 PM
Pete's Avatar
Nah you wont even have to wack em. Youre more than likely going to have to drill thru those 2 pesky small screws thou.....I didnt even replace em, I mean the lugnuts are what holds em on anyway.
ekinskofer
Jun 1, 2010 07:28 AM
Ruenin
Sep 23, 2009 05:00 AM
upssuprvsr41
Jan 10, 2009 07:36 PM
subnet76
16
Aug 3, 2008 08:15 PM
