spring compressors
Old Feb 26, 2007 | 01:24 PM
jbum's Avatar
Default spring compressors
I have a strut spring compressor that I used to installed some H&R springs last year and I'm in the process
of switching in the original springs (selling the car). I'm noticing that the compressor is hard to use
with the original springs. They are longer and flimsier than the H&R ones so they don't stay straight
when compressed. This wasn't a problem when taking them out but it's hard to align the mount cap
and struts like this.
Does anyone have any suggestions of how I can avoid this problem? I'm using one of those hand tools
that go on each side of the spring to compress. I really would love to use a real spring compressor
tool but they are all like $500.
Thanks.
jbum
Old Feb 26, 2007 | 04:17 PM
Belmont's Avatar
Default RE: spring compressors
You can rent a spring compressor from Vato Zone for 40$ and youll get your money back when you return it.
Old Feb 26, 2007 | 05:19 PM
jbum's Avatar
well, I do have a compressor. similar to the one you can rent from autozone. the only problem with trying to put the original oem springs back is that they are much longer than afermarket and tend to bend when you compress them unless you're very careful about centering the compressors constantly.
Old Feb 26, 2007 | 05:28 PM
civicexracer's Avatar
are u using 2 compressors? compressing the oem springs should real easy...
Old Feb 26, 2007 | 05:30 PM
jbum's Avatar
yes, one on each side. i agree, it was real easy when taking it off since i didn't care if the spring compressed straight/aligned. But when putting it back, i need fairly straight to put the strut and mount plates on.
ltkenbo
Dec 2, 2007 01:55 PM
FlipHKD720
Feb 27, 2007 09:29 PM
Froznface
Aug 4, 2006 12:58 PM
bw1339
Apr 20, 2006 06:53 AM
misterbee123
Apr 18, 2005 04:20 PM
