springs...(need help)
#32
RE: springs...(need help)
just the fronts. there is also a little do-it-yourself thing for the rears. it replaces the stock bolts on the upper arm and you get shims to put behind them, it corrects up to 3 degrees of negative camber. i can include the bolts and shims, same price.
#33
#35
nope, its pretty easy, its kinda tricky to hold the shims in line while you stick the bolt through. the one on NTXs link is way better, but as you can see, it another 100+ dollars. ill give you the shims free if you want them, but if you want to get the adjustables for the rear like NTXs, go for it.
#39
Just a note, if you install firmer springs (which most lowering springs are in comparison to stock) on stock struts/shocks the springs will overpower them. You get a "pogo" effect over bumps. Besides skittish handling, it will cause your stock struts/shocks to wear faster. This in turn magnifies the bouncing.
Ramyswar
02-04-2012 05:09 PM
SinisterCivic1
03-31-2010 11:42 AM
tuong
04-27-2008 02:35 PM
tuong
04-16-2008 11:28 PM
aznxboi19
10-10-2005 11:53 PM
