Strut replacement
Old Sep 11, 2005 | 09:28 PM
Sharpshooter's Avatar
Default Strut replacement
I replaced the front struts on my 94' civic with no problems, but when I went to do the back the bolts for the struts are rusted on. Even with a impact wrench they will not loosen. I had the control arm off with the strut on it and could not get it off. Any ideas other than grinding them off and drilling out the bolt??
Old Sep 13, 2005 | 05:14 PM
Clean98EX's Avatar
Default RE: Strut replacement
There could be a couple of things going on. When I did my suspension, it looked like the nut was actually tack welded on to the strut. I would get a torch and just heat up the nut which will make it expand and make it easier to get it off. If you are good with a grinder; you could grind those welds off. What ever you do, make sure you use plenty of WD or Brakleen for lubrication(while wrenching, not cutting!!!!!). But i'm almost positive that is the case. Post back if it worked!!
mundy5
Oct 19, 2008 04:06 PM
97_ex
Apr 11, 2007 02:34 AM
FlipHKD720
Aug 12, 2006 03:28 PM
rbrad9753
Jan 23, 2006 09:34 AM
mahmi
Aug 18, 2005 02:56 PM
