Tire\Tyre Perfect Pressure for 205/45/16
Old Mar 20, 2007 | 12:05 AM
Biohazard's Avatar
Member
Default Tire\Tyre Perfect Pressure for 205/45/16
I've got 205/45/16 Toyo Proxies and was wondering whats a decent PSI level to maintain these Tyres!
Old Mar 20, 2007 | 10:54 PM
Kommando's Avatar
Default RE: Tire\Tyre Perfect Pressure for 205/45/16
It depends on your driving conditions and the weight balance in the car. For mostly tame daily driving, take a fat piece of chalk and mark across the tread, then roll the car a few yards and check the wear. Wear in the center means you need more air. Wear on the outer edges means you need less air. Even wear means you're about right in the ballpark. For best mileage, keep the pressure towards the high side of the evenly-wearing range.
For aggressive driving, you're probably going to want to up the pressure somewhere to just under the max PSI printed on the sidewall. This will keep the beads from peeling off the rim when considerable lateral forces are applied during hard cornering, keep the tires from spinning on the rims when braking or accelerating hard, and keep the tread more evenly planted during cornering. Do not exceed the max pressure printed on the sidewall and drop a few PSI if the tires seem to bounce too harshly over rough sections of pavement. Tune the pressure accordingly for other factors.
Old Mar 20, 2007 | 10:59 PM
blackmetal619's Avatar
it should say on the tire themselves what psi to run at
Old Mar 20, 2007 | 11:23 PM
ORIGINAL: blackmetal619
Not always.... my Cooper Zeon ZPTs (205/40-17)don't say... I'm going to have to try that chalk thing next month when I put the 17's back on, though...
Old Mar 20, 2007 | 11:24 PM
i see.i dont really follow the tires too much, i rely on what feels best
Old Mar 22, 2007 | 08:00 AM
Nochek's Avatar
Max pressure numbers on a tire are for exactly that, max pressure. I run my tires at 32 psi, because at max pressure I get an extra inch or so bounce out of my wheels, making control harder
HStack
Dec 11, 2011 04:29 PM
jdholi2003
Mar 13, 2007 08:12 AM
Biohazard
Feb 13, 2007 10:57 PM
BigDizza
Sep 28, 2006 09:55 AM
crxguy89
Mar 23, 2005 02:22 PM
