tire size/ milage question?
Old Nov 9, 2008 | 07:27 PM
conceptualpolymer's Avatar
You are absolutely correct. According to my calculations, your OEM tires are 22.65" in diameter and have a circumference of 71.16", so for every mile, each one turns 890.4 revolutions. With the larger tires and wheels, that many revolutions will get you 1.025 miles instead of 1 mile. Multiply that by the number of miles you've driven and then divide the answer by the number of gallons of gas you've used and the answer will be your gas mileage.
Old Nov 9, 2008 | 07:57 PM
^ is it possible if you can help me with finding the number to multiply with my number of miles. my cars stock size is 185 65 14 and i am currently running 195 60 14. its not a big difference but i just want to get a more accurate MPG
Old Nov 9, 2008 | 08:10 PM
when you fill up and do your calculation, multiply the miles on the trip count by .989 (or .99 will work just as good)
you are actually only traveling 98.9% of what your trip count says
Old Nov 9, 2008 | 08:55 PM
thanks
Old Nov 10, 2008 | 01:56 PM
This is correct. I will type in the calculations a bit later.
Old Nov 10, 2008 | 07:41 PM
Default Tire size calcs
First, calculate tire diameter:
185 x .65 x 2 x (14 x 25.4) = 596.1 millimeters, so 596.1/25.4 = 23.47 inches diameter
195 x .60 x 2 x (14 x 25.4) = 589.6 millimeters, so 589.6/25.4 = 23.21 inches diameter
The first tire will travel 73.73 inches (23.47 x pi) for every revolution, whereas the second tire will travel 72.92 inches.
If your car calculates distance based upon the OEM (first) tires' revolutions, the second tire's distance will be 23.21/23.47 of the actual distance, or .989 x the actual distance in miles.
If you had larger tires than OEM, then your multiplier would be greater than 1, as is the case with the original poster.
Old Dec 7, 2008 | 08:43 AM
winkosmosis's Avatar
That 2% difference is not even worth thinking about. But also, the sizes of tires are not that precise, so the new tire could very well be 2% smaller, or 5% bigger.
apoplectic1
Apr 9, 2010 08:09 PM
addiction2bass
Aug 22, 2008 06:42 PM
davidb123
Sep 13, 2007 08:25 AM
Turbo99SI
Oct 6, 2006 11:21 PM
rpinoh1
Feb 13, 2006 02:12 PM
