Torque Rating on Front and Rear Suspension
I am re-installing the the upper front and upper rear strut bars on my 01 civic ex. I used a torque wrench the last time, but I forgot what rating or pound pressure to use. Also is a torque wrench really needed to install the front and rear struts?
*Note I already searched my owner's manuel and found nothing dealing with my issue.
Alright I found this at 7th gen
Torque specs
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear two shock tower nuts:
43ft lbs
Which applies to the sturt installation?
Torque specs
Front end links:
29ft lbs
29ft lbs
32ft lbs
33ft lbs
33ft lbs
10mm one: 7.2ft lbs
12mm one: 16ft lbs
43ft lbs
top: 28ft lbs
bottom: 29ft lbs
16ft lbs
43ft lbs
