washer trick
Old Apr 5, 2008 | 09:47 PM
javon's Avatar
Default washer trick
for the washer trick what size bolt and washer i need to to do this trick thanks is for 1994 honda civic on tein springs
Old Apr 6, 2008 | 06:20 PM
EJ8VTEC's Avatar
Default RE: washer trick
whatever the size washer add that much more thread, just screw around with it untill you get the camber setting that you want, i mean bolts and washers cost maybe 25 cents if that compared to a new $80 camber kit.
Old Apr 6, 2008 | 06:32 PM
civicexracer's Avatar
pull the original bolt out, measure it and get the thread pitch. pick up a few washers and bolts that are a bit longer with the same thread pitch and set it to w/e camber spec u want..
bmelloh
Aug 4, 2010 11:06 PM
GDizzle2
Jul 12, 2010 07:29 AM
plethoric33
Oct 1, 2007 09:33 AM
snosurfa7
Apr 25, 2007 03:41 PM
Remmy
Mar 28, 2005 11:52 AM
