1 or 2 bends
Preference of where you want the shifter to be. 2 Bends will move it closer back like a normal shifter and a 1 bend [or a strait shifter] will be farther away from you, closer to the dash.
Depends, the stock shifter has 2 bends so if you like it where it is then buy a 2 bend short shifter and it should stay in about the same place. If you want it to be closer to the dash then the stock shifter then buy a 1 bend.
