how reliable and smooth is an automatic to manual conversion?
Old Feb 7, 2007 | 04:36 PM
b3nSoNx's Avatar
Default how reliable and smooth is an automatic to manual conversion?
does the car run well after you convert it?
good shifting and reliable?
Old Feb 7, 2007 | 04:38 PM
Mr Mobsta Man's Avatar
Default RE: how reliable and smooth is an automatic to manual conversion?
It should run just like a car that was originally manual.
Old Feb 7, 2007 | 05:39 PM
drbyers's Avatar
i think ej1rider did the conversion. ask him.
the conversion can be nerve-racking because sometimes you have to actually cut metal to do the swap, but its a fairly common conversion on hondas.
Old Feb 8, 2007 | 11:40 AM
Powermidget's Avatar
Ive done a conversion on a crx dx from at to mt,when i had it and it was fine...no problems ran like the si 5sp it replaced
Old Feb 8, 2007 | 11:47 AM
mxs's Avatar
mxs
if you get good parts it should be fine
Old Feb 8, 2007 | 04:40 PM
b3nSoNx's Avatar
should i go with original parts or aftermarket parts?
Old Feb 13, 2007 | 12:58 AM
AaaronF's Avatar
ya good quesytion, i was thinking about doing the same thing. i just want to know if i should be getting all new aftermarket parts, or if i could just use stock parts.
Old Feb 13, 2007 | 04:37 PM
b3nSoNx's Avatar
and how about the gauge face?
the automatic one is different from the manual one, you might have to change it for an authentic stick shift look
94civichatchback
Drivetrain DIYs
Apr 6, 2010 09:08 PM
myaman
Mar 5, 2010 09:51 AM
Pete
Drivetrain DIYs
55
Dec 7, 2009 07:30 PM
b3nSoNx
Jan 28, 2007 07:10 PM
splman75
Aug 7, 2005 09:17 AM
