2nd gear noise
Old Nov 22, 2011 | 03:40 PM
civic674's Avatar
Default 2nd gear noise
05 civic manual transmission noise in second gear just replaced the inputshaft bearing now i have a chatter noise in transmission on light acceleration at times. Any ideas?
Thanks.
Old Nov 23, 2011 | 10:40 AM
Scott53092's Avatar
How many bearings did you replace? There's 2 on the input shaft and 2 on the main shaft. I replace both bearings on the same shaft of they are noisy, the play on one will kill the other side. The main shaft bearings are most likely okay, but it wouldn't have hurt to check those and your diff bearings. I recently did both ips bearings on my own car, the old ones were on the brink of exploding. When I took em out I couldn't believe they didn't let go after all the time I ran it like that.
Old Nov 23, 2011 | 12:30 PM
civic674's Avatar
I did replace both plus the throw out bearing. It's not a bearing noise is a rattle/chatter noise coming from inside the transmission only in second gear, if i hold forward on the shifter it gets better.
darkside
13
Sep 26, 2011 07:38 PM
Tinkerbell_too
Oct 6, 2010 05:44 AM
Juans_MX3
Apr 9, 2010 05:37 AM
busterpauliee
Apr 17, 2009 10:11 PM
djcompton
Aug 5, 2008 04:35 PM
