ATF Fluid
Old Jul 13, 2007 | 06:53 AM
byoung149's Avatar
Default ATF Fluid
Hi,
I am going to change my transmission fluid in 1996 EXand use the drain and fill method mentioned in other posts. Everyone seems to recommend using only the Honda ATF Z-1 fluid but I see that Castrol now makes an ATF fluid that exceeds the OEM ratings required for the fluids. Has anyone used this fluid yet? Any issues with it's use?
Thanks!
Old Jul 13, 2007 | 07:40 AM
Marty's Avatar
Default RE: ATF Fluid
use the Honda ATF
Old Jul 14, 2007 | 10:20 AM
blackmetal619's Avatar
yea, I try to stay as OEM as possible
Old Jul 14, 2007 | 12:05 PM
dfdon's Avatar
atf for automatic
Old Jul 14, 2007 | 02:12 PM
ef4life's Avatar
yeah atf is only for autos. and i would only run honda atf, its the best.
now manual trans open a whole new story/debate
mundy5
Jun 16, 2014 12:11 PM
DeanHensler
Jan 9, 2012 08:06 AM
groho
May 11, 2011 03:00 PM
enigma34
May 13, 2009 06:41 PM
txedomask433
Aug 3, 2007 06:09 PM
