Axle installation problems
My passenger side outer most cv joint has been clunking for a while now, boot tore a few months back. I went to autozone to pickup a replacement, I don't have abs so i bought the non-abs axle. When i went to install the axle the spline would not go into the wheel hub. So i returned the axle and went to pep boys and advance auto, with the same result. I checked my spline diameter against the replacement with a micrometer and the replacement axle was larger?? So i was running out of ideas, so i decided to try the abs axle. It fits like a charm, the only difference i noticed was that the abs axle has a speed sensor. Is this going to be a problem, because i did the same thing for the drivers side. So far no problem with the install.
08, 1995, 2005, abs, axel, axle, axles, civic, differential, due, honda, install, installation, problems, replacement, seat, transmission
