cv axle stuck/installation
Old Apr 20, 2007 | 09:18 PM
compo1's Avatar
Default cv axle stuck/installation
i cant get the cv axle to seat in the tranny .it stops about 1inch from the stop where it seals..i tried rotating the cv axle while pushing on the inner cv joint housing...i lubed it...it does not budge...there are instructions in the box it came in how to disassemblethe cv axle at the inner cv joint insert the cv axle in the tranny and then reassemble inner cv joint with the rest of axle and reclamp the inner boot...has anyone tried this method....other thoughts or suggestions ...thanks in advance...compo1
Old Apr 21, 2007 | 12:13 AM
hatch46580's Avatar
Default RE: cv axle stuck/installation
well if you got it new from a parts store theres a very high chance they sold you the wrong one, it might be the correct box but wrong item. I know sometimes they are a real bear to get in there. heres what i do. Carefully find something round and soft, like a 1 inch dowl rod, it a round piece of wood, you can get it at a hardware store, make it about 12 inches long, get your self a 3 or 5 lbs sledge hammer and place the dowl on the very edge of the cv cup, and give her a couple wacks with the sledge.She should pop in.
But before any of that i would double check you have the corrcet one. Just take it back and tell them it the wrong one, trust me 4 times outta 10 its wrong.
Good luck.
Old Apr 22, 2007 | 10:03 AM
4 times out of 10?
Anyway, it just takes a little extra "umf" to get it in there. I had a budy move it in and out a bit while I guided it into the tranny, both clicked right in
Old Apr 22, 2007 | 10:16 AM
roblinxs011087's Avatar
or try just tapping it in w/ a rubber hammer... worked for me.
Old Apr 22, 2007 | 11:18 AM
hatch46580's Avatar
ORIGINAL: Forty04
4 times out of 10?
Ya the parts stores around here are kinda ify...
ugh3012
Dec 16, 2007 01:39 AM
eagerinsight
Jul 15, 2007 09:15 PM
digimon916
Jun 20, 2007 02:51 AM
compo1
Apr 25, 2007 06:52 AM
02pmb
Feb 10, 2006 10:06 AM
