Axle replacement?
Old Jul 23, 2007 | 07:59 PM
asdfbrendan's Avatar
Default Axle replacement?
I'm currently in the process of gathering all the parts for a CVT to manual swap. My understanding is that since I'm switching to a D16Y8 tranny, I'll need to change my axles as well. Am I correct?
Old Jul 23, 2007 | 08:42 PM
jeff948594's Avatar
Default RE: Axle replacement?
i did a little reasearch into your prior posts and u have a 98, provided that the trans is a 98 (or the same type) you dont need new axles
http://www.partsamerica.com/ProductL...Shaft+%2f+Axle
just check part stores and see if they have different axles listed for the car that you have and the trans u are using, if they are the same axels your golden, if they are diff u need to do a lil reasearch.
oh and if that link doesnt work i apologize, if you go to www.advanceautoparts.com or any autopart store you can compare.
Super Mario
28
Aug 25, 2009 04:47 AM
hdzx
Oct 21, 2007 11:28 PM
Forty04
Drivetrain DIYs
Apr 13, 2007 06:13 AM
droopy128
Feb 7, 2007 10:18 PM
drosslg
Apr 16, 2005 11:44 PM
