clutch HELP!!!
Whats up
ok i have a ACT stage 2 6 puck cluth in a GSR tranny, i just got it shipped out to me an its givin my problems. First when i press the clutch in alittle bit it sinks down, normaly has alot of pressure, an it has a really hard time goin into gear 1st an 2nd...an when im at a light an *when it goes in gear, it runs rough n wants to just stall out.
Would i need to bleed the system? or is it the flywheel? the clutch has abut 4.5-5K miles
thanks
thanks
ooook soo im really stupid about trannys....theres no dip stick for the transmition...or idk where its at..an the fluid near were the brake master cylinder is ..its full maybe the pressure plate? or a bearing might be out???
there is no dipstick because its a manual.there is a bolt on the side of the tranny you take off with a 3/8 ratchet (maybe a 1/2 dont remember)then check how much fluid is in there with your finger and add if needed
I don't think that the loss of clutch pedal pressure you describe would be caused by a low transmission fluid level. Bleeding the clutch hydraulic system of potential air bubbles seems more worthwhile.
oh well i cant see the eye glass to look for the fluids, cars to low to jake up...an the intake pipin is to big an it covers the site of the tranny...soo im just lettin it sit an ill take it to a mechincs
VXHatchHero
Jun 13, 2010 09:42 AM
NIKE H34D
Jan 5, 2009 01:04 PM
addiction2bass
Apr 13, 2008 05:19 PM
jtvision
Jan 11, 2007 07:58 AM
HARI.
Oct 8, 2006 09:46 PM
