Clutch not coming back up
Old Mar 11, 2009 | 12:16 PM
  #31
Originally Posted by RonJ
I don't think that raising the front end on jack stands would be needed to replace the slave cylinder.
+1, you don't have to.
Old Mar 11, 2009 | 01:03 PM
  #32
plethoric33's Avatar
I got the car back. Is there a way to change how the clutch pedal feels? It doesnt engage now until the pedal is pretty much all the way out, where as before it barely needed released to engage.
Old Mar 11, 2009 | 01:11 PM
  #33
That's the way you want it. You want the pedal to only have to be pushed a little bit to disengage the clutch.
Old Mar 11, 2009 | 01:18 PM
  #34
well you could adjust it a bit.. pull the pin under the dash that connects the master cylinder to the pedal linkage and then adjust the rod and nut a bit.... but as long as it works perfect i wouldnt worry about tweeking it any.. your just used to your old pedal.... youll get used to the new pedal
Old Mar 11, 2009 | 02:44 PM
  #35
Old Mar 11, 2009 | 02:51 PM
  #36
RonJ has the answer to everything. haha. If you happen to have a wiring diagram for the alternator that would be great. The alternator is good but its not charging. The wires look like they have been spliced.
Old Mar 11, 2009 | 02:54 PM
  #37
...The alternator is good but its not charging. The wires look like they have been spliced.
Check whether fuse 15 under the dash is blown.
Post some clear pictures of the bad/spliced wires.
Old Mar 11, 2009 | 03:24 PM
  #38
I have to buy an upload cable first to post pics. Mine broke. Ill go check the fuses though.
20 SMOKE
Aug 16, 2014 06:39 PM
Peg_Leg
Apr 2, 2008 04:18 AM
importcivicus
Feb 6, 2008 03:51 AM
mugen1
Jul 12, 2007 09:52 PM
Remmy
Oct 31, 2005 03:48 PM
