DIY clutch replacement
Old Jul 3, 2006 | 04:42 PM
roblinxs011087's Avatar
Default DIY clutch replacement
so i'm trying to see if at all someone has done any clutch swaps? is it at all easy or just time consuming. i got a d series engine and manual tranny. so anyone done this themselves??
Old Jul 4, 2006 | 01:49 AM
finalimpact's Avatar
Default RE: DIY clutch replacement
takes me roughly 1-1.5hours to install a new clutch with 2 stands and a jack. assuming you either have a turned flywheel or a new one sitting beside you or dont turn your flywheel. its not an easy job for a not so mechanicaly inclined person. worst part imo is the bitch pin.
Old Jul 5, 2006 | 02:32 AM
could you specify which bitch pin? also is the mounting up as easy to dissasemble?? or would it be better to get a pro to do it, seeing that i want to learn a bit about trannys. i mean i've done my mechanic'ing around so just trying to get some feedback on the labor.
Old Jul 5, 2006 | 03:09 AM
bitch pin that i speak of is the pin that holds the shift linkage to the transmission. you can use a 10mm bolt to push it out but its rather a pain imo. i cant really state anything on labor as i do this for a living so its no big deal for me. but being that you do a little for yourself you maybe able to do it in a days time.
Old Jul 5, 2006 | 09:23 AM
StifflersMom's Avatar
Cat Fuсker
So that bugger was removable??????? And here I was replacing the clutch and rebuilding the tranny with the linkage attached to the damned thing...
ulmus
15
Apr 23, 2009 08:13 AM
kinosh
Jul 2, 2007 02:29 PM
Rklamb16
Jun 17, 2007 04:56 PM
danomatic93
Apr 4, 2007 08:17 AM
