electrical
Old Feb 23, 2006 | 04:24 PM
confused's Avatar
Default electrical
just swapped a 5 speed into a car that had auttomatic do i need to change any of the wirind harness? neutral saftey switch ect?
Old Feb 23, 2006 | 04:27 PM
ef4life's Avatar
Default RE: electrical
if the car runs and drives after the swap without any check engine lights, then you don't need to change any wireing. www.rywire.com and www.boomslang.us have a lot of wiring expiriance and can make you the wiring conversion you would need if you need it.
Old Feb 24, 2006 | 05:29 PM
mill$civic's Avatar
you should post some pics of the swap and what the prossess was....ALOT of people ask about doing the swap
Old Feb 27, 2006 | 12:22 AM
jwsimons's Avatar
also, if you didnt change ecu's you may have an issue, but i beleive it can be corrected with a simple jumper change in the ecu
fierychick
Jan 29, 2009 11:23 AM
davidp
Mar 7, 2005 12:34 AM
thirddensity
Jan 31, 2005 03:19 PM
Norman_x
Dec 8, 2004 02:09 PM
vk4bcp
Jul 6, 2004 03:31 PM
