GOT MY DX TRANNY! (pics)
Old Oct 2, 2007 | 09:59 PM
Hailchristian's Avatar
Default GOT MY DX TRANNY! (pics)
EASIER Question!!!!!!!!
Does a 88-91 civic SI transmission dirrectly swap with a 88 Civic std transmission..both manual.
Old Oct 3, 2007 | 06:01 PM
Default RE: 88 std to si transmission swap...
help......
Old Oct 3, 2007 | 06:43 PM
<deleted> friend got ahold of my account
Old Oct 3, 2007 | 06:46 PM
<deleted> friend got into my account
Old Oct 4, 2007 | 11:44 PM
http://honda-tech.com/zerothread/2116109
oh god...why couldnt you guys help me????????????????????
they get so crazy at honda tech!
Old Oct 5, 2007 | 04:22 PM
foress_89's Avatar
lol omg you really do need help uh I would they should fit. What engine was the tranny coupled with and what engine do you have? I think the four speed were coupled on the 1.5 litres right?
Old Oct 5, 2007 | 05:40 PM
ef4life's Avatar
so if you have a 88 hatch you can use a 89-91 trans, but you need to use the coresponding clutch for the trans your using. so a 89-91 si trans uses a 89-91 flywheel and a 89-91 clutch.
but if you have a 88 si tran you need a 88 si flywheel and a 88 si clutch
not nessesary si stuff but corresponing to the year
Old Oct 5, 2007 | 06:46 PM
yeah..they awnsered the questions..just they post way too much stuff..lol
Old Oct 6, 2007 | 09:47 PM
figure i would just make this tread it since it had some info on it already....
well..i went to pick a part with some buddies and started my search for an SI or DX tranny.....and....well plenty of cars to pick from..started looking arround found an 88 but it had an autotranny...so we finally got to the end of the imports and we se this god awful 4 door with a huge muffler and 3 shaved door handels.....primer grey...take a look at the engine...nothing there...but a dx tranny laying on the ground with the clutch preasure plate and flywheel attached.....left the clutch and pressure plate but snagged the flywheel...got the flywheel and tranny for $91!...and pocketed a benz emblem....
Also won a 88-89 integra ecu for the zc swap....things are looking good...
my question is should i replace the flywheel...im going to replace the clutch set but i dont know if i should replace the flywheel...If i did i would probalby go exedy on everything...is that a good brand?
let me know.
STOKED!~
Old Oct 7, 2007 | 12:15 PM
foress_89's Avatar
great deal. Get the flywheel resurfaced at a machine shop! It's important...
davster
Sep 28, 2007 10:23 AM
fleabiscuit_69
Sep 5, 2007 06:16 PM
pregohatch
Jul 9, 2006 09:21 AM
TrAvMaNFTW
May 2, 2006 09:53 PM
darknightmr2
Mar 14, 2006 06:44 PM
